03 c240 mileage Dosent read
Old Apr 3, 2013 | 08:36 PM
mbz03's Avatar
W212 2010 Mercedes e350
Hey guys I have a 03 c240 and I changed my cluster to a 05 everything works except the mileage Dosent display, the only way I can see the mileage if i turn the ignition from on to off and take the key out any ideas how I can get it to display Back again thanks
Old Apr 5, 2013 | 01:12 AM
samaritrey's Avatar
Super Moderator
THE C350
Well was the cluster brand new and reprogramed using star? if not that's your issue.
Old Apr 6, 2013 | 06:22 AM
mbz03's Avatar
No, how can I get star? Dealer right?
Old Apr 6, 2013 | 09:33 AM
phister's Avatar
06 C230 SS 6spd
dealer or an indy shop thagt has one
Old Apr 6, 2013 | 10:25 AM
greenv's Avatar
2003 C230 Kompressor
The car computer mileage and the display mileage don't compare is a common problem if you change the cluster. Programing is the only way to be repaired. Or don't look the odometer.
Old Apr 6, 2013 | 03:46 PM
samaritrey's Avatar
Super Moderator
THE C350
Even if you had star unless the cluster is brand new you can't fix the issue. The cluster gets locked to the car it is first installed on after a few thousand miles from my understanding.
