W203/CL203 STANCE/SUSPENSION/FITMENT THREAD
Old 06-24-2013, 09:19 PM
phister's Avatar
06 C230 SS 6spd
is the sports/amg package
Old 06-25-2013, 06:39 AM
dexmex88's Avatar
Mercedes C280 4Matic
Damnit I thought so. Is the bumper actually different from the luxury or just those pieces? I'm just trying to figure out how to change it because mine just isn't cutting it. BTW I'll post my wheels soon as to not throw this too far off-topic.
Old 06-25-2013, 11:05 AM
phister's Avatar
06 C230 SS 6spd
its the whole bumper. you can order a replica from gary@suvneer a sponsor on here
Old 06-25-2013, 02:46 PM
Former Vendor of MBWorld
Suvneer's Avatar
Ihave the front lip. $260 shipped
Old 06-25-2013, 02:55 PM
dexmex88's Avatar
Interested in the bumper too. Pmed you.
Old 06-25-2013, 05:55 PM
dexmex88's Avatar
Thanks a lot, though no luck through him.
Old 06-27-2013, 08:27 PM
  #32
C230Kreepin''s Avatar
04' C230K
Questions: would these be a good alternative to the OEM camber bolts?: http://pannauto.com/spc_performance/...r/g-62332.aspx
Or am I better off with just getting them from RMeuropean? If so how many do I need? I just recently got back into doing stuff to my car. Moving to England and traveling have taken up alot of my time =)
Current Specs:
2004 230K
BC Racing BR Coilovers
nothing else... Lol
Old 06-27-2013, 08:45 PM
  #33
phister's Avatar
06 C230 SS 6spd
you really need the fluted for the fronts. to use the other bolts youre gonna have to drill out the hole to make it fit
Old 06-27-2013, 08:48 PM
  #34
04' C230K
Ok so just get these guys right?:
http://www.rmeuropean.com/Part-Numbe..._D18BD03A.aspx
http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx
Old 06-28-2013, 01:11 AM
  #35
mchugh777's Avatar
2004 C230 kompressor
Ok guys, I have an 04 sport sedan and want to lower it. Problem is I can't afford coilovers so I was going to go with springs. All of the spring kits I find keep the front sitting a bit to high. I want equal fender gap. Will I have to end up cutting the front springs 1/2 coil on the kit I buy??? Or is there another option when purchasing the springs. I've honestly looked at every retailers kit and the front always seems 1/2" to high! Anyways, thanks in advance
Old 06-28-2013, 05:10 AM
  #36
phister's Avatar
06 C230 SS 6spd
Front will always look high because the arches are higher than the rears so it gives the illusion of it being higher.
Old 06-28-2013, 05:49 AM
  #37
mchugh777's Avatar
I know that phister and thank you, but that does not answer my question.
Old 06-28-2013, 08:37 AM
  #38
phister's Avatar
06 C230 SS 6spd
to get what you want you'll have to cut springs. I say save up and get coilovers instead of cutting springs. That or you can raise up the rear with a thicker rear pad to make it what you want. Just remember when you lower the car on stock struts/shocks they're gonna wear out pretty quick so you'll end up having to replace them sooner than later because the strut/shock doesn't get full travel on lowered springs so the they are continuously on load causing them to wear out faster.
Old 06-28-2013, 08:49 AM
  #39
mchugh777's Avatar
K, that's def what I needed. My question for cutting the springs is how to do it successfully to prevent failure. Any specific way to cut them to........A: keep the spring from slipping the cup........B: to get it to seat correctly via the angle of cut. I was thinking half a coil? I'm assuming I would keep the CUT angle the same as the factory cut? Thanks phister
Old 06-28-2013, 12:48 PM
  #40
phister's Avatar
06 C230 SS 6spd
You want to cut the top of the spring, never the bottom. Do it in half coil at a time because it does drop it quite a bit. Just cut straight down. Make sure to paint the cut end with rust preventing paint
Old 06-28-2013, 02:28 PM
  #41
mchugh777's Avatar
K, thanks for the advise.
Old 06-28-2013, 02:46 PM
  #42
05c230rpf1's Avatar
2006 C230 Sport
Make sure you don't cut them with a torch you'll mess up the properties of the metal with soo much heat. It's not necessary but even with a grinder or such I'd personally have a lot of water nearby to keep the spring as cool as possible.
Old 06-28-2013, 02:51 PM
  #43
Zane @ Brada's Avatar
w203 C230
Im not sure why we are even having this conversation!!! Please do not cut your springs! Surely you can afford some inexpensive coil-overs.... they are less than $1000 shipped to your door! Again, please dont cut your springs. It is a terrible idea.
Old 06-28-2013, 04:13 PM
  #44
05c230rpf1's Avatar
2006 C230 Sport
Agreed but at the same time if you're gonna do something wrong at least make it somewhat safe.
Old 10-29-2013, 03:35 PM
  #45
BenzoLenny's Avatar
Mb w203, Mk4 gti vr6
on ur car
did you need the front spacers added on or u just wanted too...also did it clear the front strut with out rubbing or no
[QUOTE=phister;5609527]I'll start things off
2006 C230 SS
BC RACING COILOVERS 10KG FRONT AND 8KG REAR SPRING RATES
CCW CLASSICS
FRONTS: 18X9 +25 (10MM SPACERS SO +15 OFFSET NOW)
REARS: 18X10 +20 OFFSET
TIRES: CONTINENTAL DWS
FRONT: 215/40/18
REAR: 245/40/18
MOTORSPORTS HARDWARE 75MM BULLET NOSE RACE STUD CONVERSION
C32 AMG BRAKE SYSTEM
GHOSTRIDER REAR CAMBER KIT
FENDERS ROLLED, PULLED, AND GRINDED TABS
d
Old 10-31-2013, 04:48 AM
  #46
phister's Avatar
06 C230 SS 6spd
Need spacers to clear the c32 calipers
Old 11-03-2013, 04:32 PM
  #47
pww
pww's Avatar
'05 C55 AMG
Not so new setup, but hadn't posted it in here:
W203/CL203 STANCE/SUSPENSION/FITMENT THREAD-large.jpg
W203/CL203 STANCE/SUSPENSION/FITMENT THREAD-img_1783-1.jpg
W203/CL203 STANCE/SUSPENSION/FITMENT THREAD-969783_10151689993646832_1684157418_n.jpg
18x9 et 12 (et34 + 22 mm spacer) with a 225/40
18x10 et22 (et34 + 12 mm spacer) with a 245/35
Old 11-04-2013, 12:39 PM
  #48
tiga88's Avatar
1994 c180 Sold; 2001 c200 Sold; 2001 c240; 2010 e300; 2007 cayman 987
Originally Posted by tiga88
me me next
YEAR - 2001
MODEL - C240
SUSPENSION - cut coils, front custom honda crv and rear cut h&r
WHEELS - Carlsson 1/16 front: 19x8,5 +40 with 20mm spacer, Rear: 19x10 +45 with 20mm spacer / or with 35mm spacer in the rear before
TIRES - F: Accelera phi 225-235/35 (gonna use 215-225)
LUG STUD CONVERSION - none, just longer oem bolts (am i correct)
BRAKE SETUP - OEM
WHAT REAR PAD # - rear #1
OEM camber - approx. 2.8 degrees neg. camber in rear
updated version,
front: 19x8,5 +20 (+40 with 20mm spacer), Rear: 19x10 +18 (+45 with 27mm spacer)
TIRES - F: Accelera phi 215-225/35
using less shockabsorber stopper some more, more soft feeling
Old 11-04-2013, 01:00 PM
  #49
Moderator Alumni
TruTaing's Avatar
w203 m112
Tiga - your car looks awesome! I wanna see more pix of what your rear stretch looks w/ 225s on a 10" wheel :x Those side skirts really make that lip kit work imo! :P
Old 11-06-2013, 05:38 PM
  #50
03c320's Avatar
03 c320
Why is my 19x8.5 with a 32 offset and a set of 15mm spacers still rubbing on my strut?
Quick Reply: W203/CL203 STANCE/SUSPENSION/FITMENT THREAD
