Bulb change help
Old Aug 25, 2003 | 02:27 PM
new-c320's Avatar
C320 sports
Question Bulb change help
I am thinking about changing following
1> City Lights with - Philips Blue Vision
2> Front Trun Indicators with Philips Silver Vision
3> Back Turn Indicators with Philips Silver Vision
Will this work ?
Will this require extra adaptar / other stuff ?
Old Aug 25, 2003 | 06:16 PM
JimB's Avatar
2000 ML320/'03 C320WZ
if you are going to use the same type/size of
bulb you don't need an addpter, but if you rae going to replace your bulb with LED then YES, you will need a load equalizer to make it work,,,,,wiyh out it your computer will tell you that you have a burn out bulb and the flasher will blink faster than normal.
