Service light
Old Aug 26, 2003 | 03:50 PM
blackbeard700's Avatar
Service light
Hi people, my service Type B is do in about 1000 km and i was going to get the things done, at my garage instead of the dealership. I was wondering, how do we remove the service light, or how do we reset it?
Also i'm do for the Service B i checked in my manual and they name a few things that the dealer is supposed to do.
If i get my brakes inspected, oil changed, check all fluids, rotate tires shoudl i be ok? (for the garenty )
Old Aug 26, 2003 | 04:06 PM
keep in mind that my service manual is not in english and its in french and i have a real hard time reading it
hence the call for help over here
Old Sep 2, 2003 | 06:50 PM
still don't have the anwser boys and girls?
hehe
Old Sep 2, 2003 | 07:08 PM
Hal H's Avatar
2001 CLK320
Yours might be like this -
get your display to show the Service B screen by toggling to the appropriate area.
On my car (W208) the left side of the instrument cluster has the buttons for dim / brighter display intensity and the reset "R" button.
With the key in the #1 position (engine doesn't need to be running - just ignition on)
push and hold the 'R' button in until the display resets itself to the "A" schedule and the default value of 10,000 miles (or whatever the KM equivalent would be...23,000 KM??)
You may get a question asking if you want to reset the service interval before it does it to prevent accidentally resetting when not intending to.
The system alternates between "A" and "B" service schedules.
Other than that, they ought to be very similar.
Old Sep 2, 2003 | 07:49 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
hehe
Learn French? Don't let *etenn* see this. (j/k)
Old Sep 2, 2003 | 08:17 PM
Lynn's Avatar
The following is from the Service Booklet:
B-Service
Interior
Function Check
Check Tlel-Aid by pressing SOS button to make a test call.
Horn, head lamp flasher, turn signals
Warning/indicator, illumination and interior lighting
Exterior lighting including headlamps
Headlamp cleaning system
Check seat belts for damage and proper function
Reset FSS counter
Wheels, Brakes
Brake test, parking brake check
Remove and install wheels. Rotate if needed
Check brake pads for lining thickness front and rear
Check condition of brake disks front and rear
Check tires for damage and condition
Measure and record tread depth
Correct tire inflation
Underside of car
Check major components for leakage
Check condition of front axle ball joints and rubber boots
Check condition of steering mechanical components and rubber boots
Engine Compartment
Engine oil and filter change
Check and correct fluid levels
Engine cooling system, antifreeze and corrosion protection
Brake and clutch system fluid
Windshield/headlight washer system
Battery, Check and correct fluid level
Check condition of poly-V-belt(s)
Lubricate throttle linkage and check operation and condition
Replace dust filter
Check hood and hood safety catches for proper operation. Replace components with even the slightest malfunction.
Body
Check headlight aiming, adjust if necessary
Replace windshield wiper rubber inserts
Trunk
Check spare tire inflation
Other things to do that are not included in scheduled service include replacing the brake fluid every two year and the coolant every three years.
Old Sep 2, 2003 | 08:51 PM
thank you it worked like a charm!
