Upgrade from standard MB Radio to MB Comand Unit but does not power
I have recently upgraded my MB radio to the MB comand unit however the comand unit does not power on!!
When upgrading I tested my previous radio and it was working however when unplugging it and plugging in the comand unit it was not powering up, no logo no nothing!!
Anyone experienced this issue?
I don't think its fuse related as my previous MB radio powers up.
Thanks for the help in advance!!
I generally test units on the workbench before taking the time to place them in the dash. Are you sure the unit was working when you received it?
It should be a simple matter to test the voltage on the B+ lines in the car. Never assume the fuse is good. It only takes seconds to measure it.
My location is UK, London and the car in question is a Mercedes C180 2005.
I have attached an image of the actual model number to this
thread...
You can look at the fiber optic connector in the trunk to be sure:
Skylaw posted this on another forum to distinguish D2B from MOST:
http://www.benzworld.org/forums/audi...ml#post3434579
I have been unable to determine if the COMAND you have is MOST.
Well it most probably is a MOST as the cable that was in my previous device fitted perfectly...
not sure as to what the issue could really be, so I am open to suggestions and help!!
