Question about disconnecting battery for audio work
Old Jun 19, 2013 | 04:44 PM
MiiLaNz's Avatar
2003 C320
I am looking to install a new head unit and like always when you work with electrical equipment you should turn the power off or disconnect the battery. I was wondering what the proper way of disconnecting the battery is. I read that I only needed to remove the negative cable from the battery and then proceed. When finished i just connect the negative cable to the battery again and everything should be fine? I am a bit skeptical from seeing a bunch of threads about warning errors that come from disconnecting your battery. Does this sound correct?
Old Jun 19, 2013 | 06:03 PM
funnyent's Avatar
c230k
That's correct. You will have to reprogram your auto windows (numerous threads on how to do it) but it will take only 30 seconds to do that. It's always best to disconnect the battery so you don't accidentally short something out. Just remove the negative cable, and then put it back on when you are all done.
Old Jun 19, 2013 | 06:22 PM
MiiLaNz's Avatar
2003 C320
Thank you! I read up about the resyncing of the windows and all I just wasn't sure if i would get any SRS errors or anything else.
Old Jun 19, 2013 | 06:28 PM
funnyent's Avatar
c230k
This will prevent you from getting those. From experience working on my car, the only time that happened was when I left the battery connected and accidentally bumped a wire, which I believe caused the SRS error.
