SRS codes from Star - need some advice
Hi All,
I pulled these codes from STAR today:
Any ideas on how i can go about fixing this? So far ive swapped out the seat belt buckle and tested it with a functional one and ive also checked all the connections..![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Thank you!
- B102E The resistance value in the ignition circuit containing component Current and R12/2 (Front passenger ETR ignition squib) is too low. stored
- B1059 The coding for component S68/4 (Passenger-side seat belt buckle restraint systems switch) is faulty.
Thank you!
the battery is approx 1 years old.. the STAR diagnosed it as OK.. i wonder what else could be the culprit.. possibly the seat belt retractor
