Resolve premature inner edge tire wear
The very latest K-MAC patented design front Camber, Caster and Rear Camber
Toe Kits are now available to suit virtually every model Mercedes 1968 to 2013.
Majority of today vehicles, because
of cost cutting and speed of the assembly
lines only have Toe adjustment.
K-MAC Engineering
Toll Free 24/7# 1888 414 0762
sales@k-mac.com
www.k-mac.com
K-MAC Engineering - YouTube
Unlike the O.E front “one setting” offset bolts all K-MAC kits provide precise adjustment
(accurately under load, direct on alignment turntable) and more than twice the adjustment range.
This increased range and precise adjustment capability means at last ongoing issues of steering pull to one side, straight line high speed directional control, excess inner edge tire wear or being able to reduce lap times by increasing front negative Camber on race days can now all be resolved.
Fitting of these front and rear kits requires no special tools and allows future ongoing adjustments when altering height, fitting wide profile tires or simply to re-adjust for curb knock damage.
The adjustable front caster bushes also reduce dive, lift under brake and acceleration, along with improved steering response and traction under braking. They feature a unique K-MAC 2 axis/all positional bush design. This allows suspension arms to travel through their required arcs without binding. Also having twice the load bearing area of OEM rubber bushings that use air voids which can cause vibration, wheel hop with loss of traction under braking and subsequent premature bush failure.
An added bonus with the K-MAC adjuster kits is an entire bush upgrade as these 4 bushings for the front and the 4 for the rear are the vehicles main high wearing suspension bushings.
Example of K-MAC bushing strength/quality is the near identical bushings being used in the current Australian and New Zealand V8 race category where the G8 versus Ford. This all out competition racing – main straight top speed, then hitting race curbs, slamming down after becoming airborne! After 18 months of evaluation race scrutineers ruled the evidence had shown that for the safety aspect and reliability no other front end Camber and Caster adjuster kits other than K-MAC would be allowed to be used. The opposing Ford drivers were also instructed likewise.
K-MAC has been manufacturing adjuster kits longer than anyone else and amongst the many advantages of the patented designs – 2 of the most important features are:
- K-MAC kits are designed to adjust lower, not upper arms, effectively maintaining clearance top of tire to outer fender when wanting to reduce inner edge tire wear. Essential if wide custom wheels or wide profile tires fitted.
- We have ensured that K-MAC kits unlike virtually all other brands, do not use solid, metal to metal spherical bearings that besides ride harshness anyone in motor sport know they prematurely pound out. Instead all K-MAC patented design bushings are elastomer. Allowing 2 axis movement yet eliminating the air voids and/or fluid of OEM bushes. Result is, precise adjustment capability, improved steering, traction and braking response with extended wear life. Having twice the load bearing area of OEM bushes and no unforgiving metal to metal contact of spherical bearings.
Audi to Volvo
