Oil Level Warning
Oil consumption of under 0.25 L (half pint) per 1000 km (621 miles) would be entirely normal and acceptable.
Sure, drive it to the dealer, or top up the oil yourself and record the amount. No problem either way.
The obvious answer is "add more oil", since you're clearly on the very low end of acceptable.
All cars burn some oil; because ours have the long time between changes, it just shows up more, law of averages.
Contact your dealer if you must, but I'd just add more oil until your level is fine, and move on with your life. It shouldn't be a big concern. Hell, I've been adding oil since I picked up the car - to register a "problem", you have to be burning oil like there's no tomorrow.
