Brake problem 2003 c320 4M
Is there no braking or is it that you have to press extremely hard on the pedal to brake?
You can probably compare the effort with the car off after sitting overnight, vs the car on after sitting overnight.
Also I believe someone on this forum had his brakes bled, and then found that the shop introduced air to the system. (don't remember what the symptoms were though)
