Rear View Camera
Old Sep 19, 2013 | 01:00 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
Rear View Camera
Has anybody retro fitted a rear view (backup) camera on W203 body
Old Sep 19, 2013 | 02:24 PM
cambiecbc's Avatar
c230
I got wireless parts from Ebay and powered from reverse light. Front monitor uses glove box light power.
The camera is Sony CCD + wireless transmitter & receiver +foldable 4.3" monitor. The camera received is not fitted in licence plate light socket.
I have to modify the size. A large hole has been drilled to fit the RCA cable
and all transmitter with cables attached inside the trunk.
Old Sep 19, 2013 | 02:42 PM
Dr.J's Avatar
C320 2001
your camera will be ripped of its to exposed cambiecbc!! i bought one also for my c320 but still havent installed it once i do will post pics
Old Sep 19, 2013 | 03:05 PM
kirax2's Avatar
I drive a Toyota Hybrid...
how did u run the cable once u are through the trunk?
Old Sep 19, 2013 | 03:50 PM
cambiecbc's Avatar
c230
The wires with black, green white is the camera power cable going down from top.
The cable was tired by cabletire as shown on pic 6 along the hinge down to bottom.
Old Sep 24, 2013 | 01:19 PM
Preet's Avatar
so how does it mount on the trunk and what did you had to modify to make it fit?
can you post a picture how it's mounted to the trunk
Old Sep 24, 2013 | 05:12 PM
cambiecbc's Avatar
c230
This is a set of wireless reverse camera. The transmitter sat within the left side of photo #5 with cable tires and tape. The black cable with cable tires is the power connect to reverse light. The left license plate lamp was replaced by the camera unit. I have to cut off and file some parts of the plastic to let it fit into the position.
Drill a 11mm hole for RCA cable to go into the trunk. Seal the surrounding to prevent water and rain.
I put the receiver unit inside and under the front speaker grill. The power is from the glove box lamp with cable going alone the window side.
Old Sep 24, 2013 | 05:28 PM
cambiecbc's Avatar
c230
Old Sep 25, 2013 | 12:46 PM
Preet's Avatar
thanks for the pic's, so did the clear oem lamp lenses get replaced with the clear lenses that the camera came attached with, but the shape of the after market lenses looks different?
Old Sep 25, 2013 | 01:19 PM
Alswag's Avatar
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
I retrofitted a wired back-up camera in my coupe. I had to wire it from my trunk, all the way to my head unit. Get creative where to hide the wire. I went through the trunk cover, under the passenger seats, under the carpet, behind the dash, to the unit.
My camera just screwed onto two screws that hold the license plate.
Old Sep 26, 2013 | 12:39 PM
Preet's Avatar
which one did u get?
Old Sep 29, 2013 | 10:00 PM
Alswag's Avatar
Honestly, I have no idea. I purchased it over a year ago, and the box had no brand or anything on it. Neither did my head unit.
But the set up only cost me about 250 bucks and it's worked perfectly for over a year.
Old Sep 30, 2013 | 01:22 AM
cambiecbc's Avatar
c230
My whole set of wireless reverse camera as shown from photo 1 to photo 3 cost about
us$60 from Ebay for free shiipment.
