Hey everybody... I wrote about this earlier but I have new information. I began hearing a thud thud thud sound as the vehicle is driving, the thud sound picks up as the speed of the vehicle increases speed, common sense, just wanted to be clear. I noticed the inner drive axle boot was torn, grease sprayed everywhere. I went ahead and removed the axle, replaced it with a new one successfully. The noise however is still there. Sounds like it's coming from the front drivers side area. Difficult to pinpoint what is wrong. I rotated the rear tires to the front, front to the rear. Still have the noise. Checked the tires for damage, nails, tire pressure, all ok. Checked all 4 alloy wheels for cracks, no cracks. Side note... we had one rim welded/repaired as there was a crack in the rim sometime ago. The noise DID NOT start after the rim repaired.
Had a foreign garage repair shop test drive the car. He, for free, said it's not the bearing in the hub as the noise is not a grinding, sandy, bearing noise. I'm tempted to replace the tires as it's about time however I am convinced it's something else. What do you guys think? Hoping someone experienced the same thing. Thanks
