Wheel bolt length
Old Oct 21, 2013 | 02:05 PM
boblaz11's Avatar
99 E55
Wheel bolt length
I have an 02 C230 Coupe. I just bought a set of C43 17x7.5 wheels. They seem to fit fine (need spacers) but the front bolts are about 27-28mm. the tire shop said they wouldn't work in the rear so used some 39-40mm bolts. I have several questions...
Are the front bolts ok at the shorter length?
If I am getting 10mm spacers should I just add 10mm and get 50mm bolts for the rear?
Should I be using the 39-40mm bolts in the front also?
I measured from the base of the seat.
I searched and got spooked by the rear e brake concern. Thanks
Bob
