wheel hub replacement
Old Oct 22, 2013 | 06:07 PM
aztekwarrior56's Avatar
2004 C230 Sport/ W203
I have a 2004 C230 sedan. i need to replace the passenger side wheel hub and bearing. besides the actual wheel hub and bearing, what other parts/ tools/machine press will i need to get it off and back on? also does anybody have any advice of pictures on how to get it done? i little guidance would help.
Old Oct 22, 2013 | 08:41 PM
wvadam's Avatar
C230 COUPE 2003 M271
oh man this is so easy. I just did it on the weekend. you need a common metric socket set, and a torx driver. remove the wheel, remove the brake caliper and don't let it hang by the hose (suspend it with wire). Then pop off the bubble shaped hub cover in the center of the hub. use a 5mm allen key to un screw the lock holding the nut to the stub axel and pull off the hub. slide the new one on and put everything back. look up procedure for tightening bearing nut. basicly you tighten it while spinning the hub a few times until it is hand tightened as much as you can, then back it off a tiny bit until it runs freely again.
Old Oct 22, 2013 | 09:03 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Perhaps this may help you:
Old Oct 22, 2013 | 09:20 PM
i need to replace the rear one man. i heard its a little more complicated because the hub and bearing dont come assembled
Old Oct 22, 2013 | 09:48 PM
VVF's Avatar
VVF
Then why didn't you specify it in your first post?
See the attached pdf
File Type: pdf
Old Oct 23, 2013 | 03:51 PM
you are a life saver!! i havent been able to find this info ANYWHERE! LOL
Old Jan 30, 2014 | 06:25 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
do you need to have the vehicle alignment redone after this since you are disconnecting all of these components?
