Changing the rear brake shields
Old Oct 25, 2013 | 11:19 AM
mostafaberg's Avatar
W203 C200K (2001)
Hey guys, my rear e-brakes recently popped off due to a very rusty shield, they no longer had anything to attach to.
finally got the new shield, but needed some tips on replacing it, upon examination it seems that i'll need to
1-Remove wheel bearing and hub
2-Remove the axle shaft
3-Remove the old shield
Then replace and put things back in reverse order, I'm using the attachment as a reference !
Am I doing things right ? anyone has done this before ? and do I need to have those special tools ? or will the hub fit without any tools ?
Let me know if you need a writeup with images !
install wheel carrier.pdf
