sunshades
Old Sep 15, 2003 | 03:07 PM
SC04ksedan's Avatar
04 230k sedan
sunshades
Intalled this a week ago, as anybody else done this? Installation was very simple. It keeps the car cooler, specially with the 100+ temps these past couple of days in the bay area.
Old Sep 15, 2003 | 03:08 PM
SC04ksedan's Avatar
04 230k sedan
right side
Old Sep 15, 2003 | 03:09 PM
SC04ksedan's Avatar
04 230k sedan
Inside
Old Sep 15, 2003 | 03:40 PM
smoothb's Avatar
2003 C320
You should of just tinted your windows???
Old Sep 15, 2003 | 04:18 PM
JimB's Avatar
2000 ML320/'03 C320WZ
I agree. I got one but
I returned it after I see how difficult to lower the window. You have to take the shade manually. its PITA. SO I had my window tinted instead
It's look nice thou, when installed
Old Sep 15, 2003 | 04:30 PM
tberry's Avatar
2002 C230 Coupe Black/Charcoal C5 C7 Auto
wow ummmm damn.....do they make matching curb feelers and one of them circular blind-spot mirrors to go along with those shades? one word: TINT
Old Sep 15, 2003 | 05:31 PM
sinyo1's Avatar
I have this...
how you install the last clip... last you open your door cover... and install the handle clips....
let me know....
Old Sep 15, 2003 | 05:50 PM
SC04ksedan's Avatar
04 230k sedan
[QUOTE]I have this...
let me know....
The handle clips grasp a little ledge bewteen the weatherstrip and the door. The bottom clips are done with screwdiver and pressure, on this you must have the plastic handles attache to the metal piece. Hope this helps.
BTW, the car is already tinted (blue tint), this is extra shade for hot days.
Old Sep 15, 2003 | 05:56 PM
sinyo1's Avatar
ok, I got that...
mine is hold ok.. for the front.. how about the rear close by small windows?
they have 2 clips.. fron and rear right.... when you look the first pic. On the left hand side..... how you install that.. I try.. many time still can put bettewen the the windows and the door panel. because the windows can't open...
what Im doing i just put double tape on the last clips...
Old Sep 15, 2003 | 06:04 PM
SC04ksedan's Avatar
04 230k sedan
[QUOTE]I agree. I got one but
I can lower the windows without taking the shades of... maybe it's a different design. Shades will stay in place with the windows rolled down, to take the shades off there are two clips on top with pull handles (tape like piece of plastic). I don't have good experience with tints, this cost me $100/pair and I get the results I want.
Old Sep 15, 2003 | 06:08 PM
SC04ksedan's Avatar
04 230k sedan
[QUOTE]On the left hand side..... how you install that.. I try.. many time still can put bettewen the the windows and the door panel. because the windows can't open...
This is where you need the screw driver and pressure. Place a piece of plastic between the window (small window) and the screwdriver than apply some leverage on the metal piece. It seems difficult but it will go into place.
Old Sep 15, 2003 | 06:12 PM
tberry's Avatar
[QUOTE]Originally posted by SC04ksedan
I hope u're not talking about the so called "tint" (aka a bluish hue) that comes with Sports pkg sedans. I mean like a real tint...say like 30-35% in the front 2 windows, and 20% in the rears and back (at least thats the legal limit in TX, dunno about your state).
Old Sep 15, 2003 | 06:25 PM
Drew_ML's Avatar
'00 ML320 Elegance/'03 C320 4-matic
The easiest thing to do, I found, was simply to remove the door panel. After that, the installation was extremely simple. I do have my rear windows tinted, however these shades block out significantly more glare than the tint does, and helps to reduce the heat in the cabin even more so when the vehicle is parked outside on a sunny day. Additionally, it matches the power rear sunshade as well.
Old Sep 15, 2003 | 07:05 PM
SOC320's Avatar
2003 C320 4Matic
Hi, all.
We have them on ours. Does anyone find them to be a problem when driving, looking back over your left shoulder out the rear left window, and trying to merge to the left. At an extreme angle, you can barely see through it.
Old Sep 15, 2003 | 07:27 PM
SC04ksedan's Avatar
04 230k sedan
Smile no problem.
I know what you mean, but I don't find it difficult to see. I speed up when changing lanes to make sure I don't cut anybody off.
Drew_ML
Do you have writeup/instructions on the led's. Can you tell me exactly what to order.
Thanks -
Old Sep 15, 2003 | 09:35 PM
SOC320's Avatar
2003 C320 4Matic
Re: no problem.
Drew_ML
Thanks -
I speed up too when changing lanes, but in NYC people move at some pretty obnoxious rates.
Old Sep 16, 2003 | 12:21 AM
Drew_ML's Avatar
Originally posted by SOC320
Hi, all.
Yes, this is true. When viewed from a certain angle, the mesh is not always easy to see through. However I have not found this to be a problem since I have the Euro blindspot mirrors suctioned-cupped to both sides of the windshield. With these in place, I do not have to turn at all to check the blindspot. A quick glance is all that is required. The 2" ones mounted outside the car require more attention to glance at, and are primarily used for parking only now (to see the painted stall lines).
See this link for more pics:
Click here for the pics
Old Sep 16, 2003 | 12:23 AM
Drew_ML's Avatar
Re: no problem.
Drew_ML
Thanks -
It depends on which LEDs you wish to have. City lamps, side markers?
Old Nov 15, 2003 | 07:08 PM
Daddymac's Avatar
Acura EL, C230K, 997 C2
Does anyone have the electric rear sunshade option on their C? Is it sunshade for the rear window or the rear door windows? Any pics of it in the up and down position?
Old Nov 15, 2003 | 07:24 PM
JimB's Avatar
here when its up
I will find the pix when its down:
Old Nov 16, 2003 | 02:20 PM
otmal's Avatar
where is this shade avail at?
any local store? or through web?
thanks
Old Nov 16, 2003 | 06:58 PM
Matt230K's Avatar
2010 C300 4matic
Re: where is this shade avail at?
thanks
It comes with the car if you choose the right options.
