c230 2006 front sam module repair
Old Nov 23, 2013 | 02:26 AM
cambiecbc's Avatar
c230
Did any expert repair the front sam module that the right low beam was always on even not ignition turned on?
Any suggestions point to malfunction components?
Old Nov 23, 2013 | 01:36 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
get a used sam of ebay, there are too many connections to check and to know the values!
Old Nov 23, 2013 | 02:36 PM
cambiecbc's Avatar
c230
already got one from Ebay and fixed.
As DIY fans, just want to repair for fun.
It seems the 6133D high side power switch burnt out.
Try to find and replace.
Old Jul 3, 2018 | 11:28 AM
Miloshev's Avatar
W203 C240 2.6l
I have the same priblem but with the right high beam light always on. Which will be the deffective switch in my case?
Thank you very much in advance.
Old Jan 29, 2019 | 07:21 AM
johnathan1's Avatar
2001 ML320, 1998 E430
bump?
Old Nov 16, 2019 | 11:32 AM
FMBUSH's Avatar
2007 ML 320 CDI
Was it a simple swap or did you have to reprogram the SAM?
