Problem with W203 key fob
I read most of the topics referred to the problems on key fobs for C class W203. I have a problem and need your assistance. My 2 key fobs won't work from distance (RF) only from close range. I read that it might be fuse number 8. Checked that and fuse is ok (7.5A). It's a 2003 model sedan with no alarm and fuse does not blow as other users indicated as a problem (with alarm system). What should I check for? How do I find the amplifier to check if that is the problem? What other reasons might be causing this?
P.S. I checked both my keys with a key specialist and they are both ok
Search for discussions on the receivers in the door handles; that seems to be the overall weak point in the system that people have had replaced (and yes, it's expensive).
I started to have similar problems years ago; had the MODS4CARS module installed in my car, and it's worked perfectly since. It wasn't cheap (around $300), but it does take care of the problem completely, and gives you some nice benefits too.
Also, you should generally take the info here with a grain of salt, and verify things before proceeding based solely off of what someone here said. Unless it's Glyn, who is always in the right (just ask him
). Anyway, good luck with your current situation; it's something that almost everyone here has been through, unfortunately (like the fading in the heat MFD issue in the gauge cluster), and there are several approaches to take.
Tommy, I know how u meant it; I just used ur "expression" in my conversation with lil, just to emphasize my point; either way I really thank you for ur reply and suggestions. I'll look into them. Who's Glyn btw? Ohhh ... and I do have an issue with my MFD but I wouldn't expect otherwise, especially with the temperatures here!
well, it used to work from more than 30m (if I remember correctly). That's 100ft+ and yes, it happened all of a sudden. I don't have any ting on my car!
Key
rear amp
rear antenna
wiring
You said you have two keys and they were tested but I have never heard of a test for range so maybe it is the key...
Rear amp is a common issue but that is usualy after water gets into them after a tint job.
Rear antenna could have been damaged/leads cut any rear stickers or anything?
wiring could obviously be an issue but as it works to some degree I doubt it.
To be honest if it works when your close to car I would say move on its an old car and without blindly buying parts for it or getting an expert working on it. That said it would bother me too but my w203 has over 200,000 miles so I am fast to write it off but if it was my newer w211 I would be upset.
Key
rear amp
rear antenna
wiring
