Pre-Purchase Recommendations
Front suspension issues are a major item with this model, make sure everything is tight and/or see if the components have been replaced with A204 XX XX XX numbers
This isn't an ordinary Used Car Dealer. He is a car guy that sells used cars as sort of a hobby. He owned a large trailer business and sold it. He sat around a few years doing restorations and resto-mods on Chevrolets, mostly 1st and 2nd Gen F-bodies. He said that got boring and so he built the building he is in now and works Monday through Friday 9-4.
According to 300DFan on benzworld.com the engine is in the range for balance shaft failure. I have read about the balance shaft failures in a couple of threads here and on MBWorld.org. A lot of owners say that they have never had a problem over and above 100k miles. What is the failure rate on the balance shaft?
Whether that happens to you or not nobody knows it is a roll of the dice
