Replacing leather boot on a 2005 C230
Thx,
If you're trying to connect an aftermarket boot to the stock knob, good luck. Depending on the job that it is done, it will look from somewhat sh*tty to completely sh*tty.
I have no idea why you would be afraid to lift the center console trim, it just lifts up from in front of the ashtray - you don't need to do anything other than lift it, and it doesn't affect anything else. If you don't, attaching the bottom of the boot to it and have it be a successful operation will be nearly impossible.
What I have is a boot that has a finishing plastic trim piece at the top, so that it doesn't attach to the knob, but looks fine. But I also have an aftermarket knob that is lower than stock, so it kind of hides the gap between the knob and the top of the boot.
No matter what, you'll have to be creative with things. But there have been posts about peoples' solutions (including a long one on the "paper clip method" for reattaching your boot at the bottom, so maybe you didn't use the best search terms?
). And I know that I've responded to questions like yours time and time again here. But the answer is you'll probably have to take a couple of cracks at it until you get a solution that works to your aesthetic. Good luck.
I've got a leather boot pretty close to OEM so I'd think there was a mainstream way of doing this. Apparently, taking the whole part off is step one. Actually, is disconnecting the battery a necessity here? I feel like the bottom of the boot should snap into the gear box around it right? Otherwise, F it, I'm going w/ crazy glue.
