OBD CODE P0172
Old Dec 3, 2013 | 01:30 PM
p1930k's Avatar
w203 c200k
OBD CODE P0172
My w203 c200k has a code P0101 and i change the MAF sensor. All ok and work perfect with new MAF SENSOR (original part not aftermarket) . Now i have a P0172 system too rich, Bank 1
Any ideas for that code?
Old Dec 3, 2013 | 02:47 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
You may have a hose or ducting air leak. Check all is assembled tightly.
Some people spray aerostart around joints to see whether there is a air leak. The engine revs will change with the change in fuel air ratio.
Old Dec 3, 2013 | 02:55 PM
p1930k's Avatar
w203 c200k
Also the car can not start after that code ...
Old Dec 6, 2013 | 01:27 AM
carobd's Avatar
kia
Possible causes
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of “oiled” air filters can cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry. There could be a vacuum leak. There could be a fuel pressure or delivery problem
Follow:
http://www.obd-data.com/p0172.html
Old Dec 6, 2013 | 02:34 AM
Moviela's Avatar
Check the fuel pressure. Leaky vacuum hoses usually make the system lean. For rich look to pressure on the rail, leaky injectors, or bad plugs.
Old Oct 20, 2017 | 04:19 AM
huotalicusC200K's Avatar
w2010 w204 c300 amg sports package
same issue system bank 1 too rich
notice this happen after i replaced the air filter with a knn
not a pod just the one that sits in the air box
any caN HELP?
