OK "C" class guru:-)
Old Nov 17, 2003 | 12:30 PM
JimB's Avatar
2000 ML320/'03 C320WZ
Where is the inside cabin filter located at the C class Sedan??
Old Nov 17, 2003 | 01:10 PM
jbcritch's Avatar
Black C 240
I believe I found it by accident the other day while jumping off my other car. I think the "inside" air filter is located inside the lid of the battery compartment. Look in your engine bay and remove the plastic lid covering the battery. I found a white airfilter there connected to what looked like a duct to inside.
Hope that helps,
John
Old Nov 17, 2003 | 01:17 PM
Lynn's Avatar
That's right.
Old Nov 17, 2003 | 02:47 PM
JimB's Avatar
thanks, folks:-)
So, NOW we can called it outside cabin filter , because its outside the cabin, As I posted from other board, Can the batterry emit acid fume then it goes directly to that filter going to the cabin, Is that safe to be there?
Old Nov 17, 2003 | 02:51 PM
Junbug's Avatar
2004 C230W
Battery
Hopefully we have a fully sealed, maintenance free battery in there.
Old Nov 17, 2003 | 04:15 PM
tberry's Avatar
2002 C230 Coupe Black/Charcoal C5 C7 Auto
Re: OK "C" class guru:-)
Was thats supposed to be a challenge? while messing with the fusebox under the hood i saw that there is a strut-tower brace (aka strut bar) under the hood too.
Old Nov 17, 2003 | 09:12 PM
Matt230K's Avatar
2010 C300 4matic
Re: thanks, folks:-)
I used to wonder the same thing, but I guess with a sealed battery, it isn't an issue. It's not fully sealed and maintenance free, but it's sealed good enough as long as the caps are screwed on tight.
Old Nov 17, 2003 | 09:13 PM
Matt230K's Avatar
2010 C300 4matic
Old Nov 18, 2003 | 04:45 PM
BruNo's Avatar
07' ML350
the oem battery has a hose connected to the car's body pointing downward towards the road.
