W203 Gearbox oil
W203 Gearbox oil
Hello
I’m a new member of this forum and just wanted to ask if someone can help me. I have a MB W203 Year 2005. I need to change the gearbox oil (automatic ) but not sure what is the best one to purchase.
Can someone indicate?
thanks a lot
thanks a lot
W203 C320, W208 CLK 320, w209 CLK 500
http://bevo.mercedes-benz.com/bevolisten/236.14_en.html
Anything on there is ok to use, Shell atf 134 is probably the cheapest and easiest to find of those.
Verify you have the 722.6 5 speed in your car if so then the shell 134 works just fine I have run it in my car for awhile now. Usually it is easy to find if you call up your local shell distributor. As you are not in the USA I don't know how easy it is to find in your neck of the words though.
make sure you use ATF and not oil. many have assumed both are the same but not. while youre changing your atf I recommend changing the differential oil in the rear as well.
