Steer By Wire
Old Nov 20, 2003 | 04:56 PM
jim628's Avatar
Steer By Wire
Does anybody know if W203 (C240 specifically) uses Steer By Wire technology? I know the latest E (W211) does.
My car steering wheel doesn't seem to return to a straight position whenever I make a slow turn or u-turn, release the steering wheel then accelerate. I have been wondering if it is because Steer By Wire.
Thanks,
Old Nov 20, 2003 | 05:07 PM
Lynn's Avatar
Neither car has steer by wire.
The following is from the E500 specs on MBUSA:
Steering Rack-and-pinion with speed-sensing power assist and integral hydraulic damper.
Old Nov 20, 2003 | 06:24 PM
coppermine's Avatar
2001 c320
Whats the benefit of steer by wire?
Old Nov 20, 2003 | 06:39 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
It is handled by electronics which actuate electrical components to replicate the job. It is supposed to be more reliable than mechanicle components; less wear and tear, less weight, etc.
Old Nov 20, 2003 | 07:25 PM
Davidta's Avatar
C230 Kompressor SPORTS COUPE
Last I heard true steer by wire was illegal in the US. MB has been testing it for a few years now in concept cars, replacing the steering wheel with a joystick, but as far as I know in the US a manual connection to the steering linkage is required under law. So no the new E is not at least a true drive by wire system.
Old Nov 20, 2003 | 08:40 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Re: Steer By Wire
It is a RWD car, they behave differently compared to FWD which do tend to straighten themselves out.
Old Nov 20, 2003 | 09:12 PM
Lynn's Avatar
A little more caster in the front end will help the car straighten out when the steering wheel is released. Have the dealer check the alignment.
Old Nov 20, 2003 | 09:37 PM
Frank B's Avatar
2003 C240 4matic
Rack-and-pinion
Here is a quote from the Mercedes USA specification site for the C240.
"Steering Rack-and-pinion with power assist and integral hydraulic damper. Turning circle: 35.3 ft/10.76 m curb-to-curb"
Frank
Old Nov 20, 2003 | 11:25 PM
bmms8's Avatar
MB
i read in a magazine that BMW will probably have steer by wire, must be rel cool though, E just has brake by wire
Old Nov 20, 2003 | 11:45 PM
coppermine's Avatar
2001 c320
Didn't a member on this board posted that the upcoming S or C class will have "by wire" everything, eg: breaks, steering, throttle?
Old Nov 22, 2003 | 04:39 AM
BruNo's Avatar
07' ML350
throttle by wire-yes
brake by wire-E Class, SL.
steer by wire-hmmmm....BMW Z4 and new 5Series i guess. its not not really steer by wire, but both dont use hydraulic power steering pumps, instead..theres an electric motor....powering the "power steering" and d 5series has variable gears w/c can adjust the the number of locks during steering at varying speeds(known as active steering).
btw, FYI, the benz A Class has an electric power steering pump. mine died before, and when i opened it, it had microchips in it, i guess....those chips vary the degree of "assist" in the steering according to speed. maybe this is wat you mean.
mb also has "parameter steering option" w/c varies the assist factor.
