New member with some questions
Old Feb 24, 2014 | 03:12 AM
hk9583's Avatar
C320 Wagon
Hi everyone
I picked up a 2002 C320 wagon awhile back. So far I am happy with the car but have a few questions. I want to retrofit the factory comand system into the car. Navigation is almost a must for me and I don't want anything aftermarket in the car. I've done a lot of research about this and it seems like it would almost be plug and play. Looks like all I would need the comand unit, GPS antenna, and a c to c1 and c2 adapter plug. I know this has probably been asked a lot but could someone point me in the direction of where I can buy the c to c1 and c2 plug and a GPS antenna? A link would be great.
Next there is a squeaking noise coming from the rear suspension on the left side. You can hear the noise when entering and exiting the car on the drivers side and driving on a bumpy road. I was told it could have something to do with bushings or the sway bar. Any ideas or has anyone else had this problem?
Thanks for your help
Old Feb 24, 2014 | 04:14 PM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Could also be the shockers.
Old Feb 24, 2014 | 06:33 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
it is plug and play, make sure you get the correct command for the car with the correct angle, the harness can be found on ebay and the antenna as well (15bucks) put the antenna above the speedo cluster, i did this to my 2003 c240 works great and you can ad aux wire to it also so you can plug in mp3 player or phone, it will have to be coded if you want directions on the cluster. if you find one from a gl you can ad back up camera also, look on here lots of good trheards.
Old Feb 24, 2014 | 06:34 PM
corkshoppe's Avatar
Top Answer: 1
check and see if the spring isn't broken!
Old Feb 25, 2014 | 11:49 AM
hk9583's Avatar
C320 Wagon
Thanks for the replies. I've done a bunch of research on the retrofit and it doesn't seen too bad. One last thing. Would one of these adapters work? Just want to make sure before buying anything
http://www.ebay.com/itm/Umrust-Satz-Adapter-Kabel-fur-Mercedes-Audio-10-CD-APS30-auf-Comand-2-0-/200765299541?pt=LH_DefaultDomain_77&hash=item2ebe8b5b55
http://www.ebay.com/itm/Adapter-Kabelbaum-passend-fur-Mercedes-Audio-10-20-CD-APS30-auf-Comand-2-0-W203-/131041166174?pt=DE_Autoteile&hash=item1e82a9835e#shpCntId
