Draining old auto trans fluid
Old Mar 21, 2014 | 08:44 PM
Bewy's Avatar
2000 model C240
Hi folks.
Working on a 2000 model C240. Has anybody tried drilling a small hole in the torque converter to drain the fluid? Plan is to plug the hole with a small screw or pop rivet after draining. Here in Australia they want a king's ransom to drain & refill the auto trans.
Old Mar 21, 2014 | 08:53 PM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Just drain and refill twice or more. You'll get most of the old fluid out and no potential leak point.
Last edited by lkfoster; Mar 21, 2014 at 08:55 PM. Reason: Added additional cycles
Old Mar 21, 2014 | 09:42 PM
Bewy's Avatar
2000 model C240
" Just drain & refill twice or more". Trans fluid might be cheap in your part of the world but it is expensive here! It also seems to be a very wasteful & ineffective way of draining/refilling the trans.
Drilling a small hole in the converter is an old & effective mechanics' trick to drain the fluid, used on many brands of cars. So I am wondering if somebody has tried this on a C240. Draining trans & conv also assures that the trans is not contaminated with old fluid when the new fluid is added.
