fixed glove box problem
Old Nov 27, 2003 | 07:30 PM
SUNILP's Avatar
2015 E250D
I posted earlier about my glove box not closing properly and the light staying on. Well, I took a good look at it and fixed it. It's really easy. For those of you with a similar problem, look at the latch top of the changer where the glove box latches onto. If you look carefully, there is a screw under that black latch. I had to remove my changer to get to it. It's silver colored. Once you have access to this screw, loosen it and adjust the latch. PRESTO. That's it. Now my glove box doesn't rattle anymore and light turns off. Hope this helps to those with a similar problem.
Old Nov 28, 2003 | 10:45 AM
moomeh
Guest
Posts: n/a
thank you! i usually just slam the glove box really hard and that fixed the problem for a week or so. your solution is less harsher.....
