Help with HID Programming for c280...... "XENONS PRESENT" option
Old Apr 19, 2014 | 12:31 PM
Prowla's Avatar
18 C300 4Matic.
My 07 C280 is rejecting my LED HID's (the new ones with the built in fan on the bulbs). Ive had it programmed with the SDS, under the EZS (ignition switch) control module, Driving Lights setting, the "XENONS PRESENT" option was set to "YES".
But my fogs still cut in and out.
I'm i missing a step or something??? Or does the "XENONS PRESENT = YES" only applies to Headlights???
Also is there any other way to verify that the "XENONS PRESENT" option is still set to YES without going back to the MB tech???
Old Apr 22, 2014 | 12:11 AM
samaritrey's Avatar
Super Moderator
THE C350
Only applies to low beam headlights and unless you have a hid kit that you know use to cause issues as your low beam and doesn't anymore you really need Star. One of the best investments I have made was getting one as you can diagnose your own car which makes DIY work so much easier.
Link to what you bought?
