P0171 Dammit! Can't get my tags since I can't pass smog! OBD Mode 6 info. HELP!
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Can anyone here give me a definitive answer as to what I need to do to get rid of the P0171. ? Attached some info, let me know what else is needed!
So, I have a P0171 error and it's keeping me from passing smog.
Smog tech suggested my leaky brake booster (it hisses and is sucking in some air) might be the problem. But it's been like that for a long time.
MAF hasn't been replaced for a long time though I clean it religiously. Not replaced since I took over maintaining it when the 100K extended warranty expired years ago, (now at 213K !).
I replaced the Cat about a month ago, it was shot. Was getting P0171 even before I replaced the Cat.
Downstream O2 sensor is original but is still putting out a signal. (I think? Passes readiness test)
Upstream O2 sensor was replaced at 100K miles.
Never touched EGR valve.
When I use "Torque" phone app to read diagnoses I get a failure in Mode 6
Test report: Mode $06 report generated by Torque for Android
TID:$01 CID:$01
- Rich to Lean sensor threshold voltage(constant)
Max: 64
Test result value: 115
FAIL
Also checked O2 sensors- Attached are graphs at idle.
BUT the readiness checks show O2 sensors as ready.
Downstream sensor doesn't seem to get much movement.
It followed the upstream sensor almost to a T before I replaced the Cat, which is one of the indicators of a bad cat.
Here's the upstream O2 sensor at idle....
crap the downstream screenshot got lost due to my crappy phone, will re-do. But basically it's a straight line show just under .5V
In any case, can anyone here give me a definitive answer as to what I need to do to get rid of the P0171.
TID:$01 CID:$01
Max: 64
FAIL
TID:$02 CID:$01
- Lean to Rich sensor threshold voltage(constant)
Max: 64
Test result value: 19
PASS
TID:$02 CID:$02
Max: 64
Test result value: 12
PASS
TID:$03 CID:$01
- Low sensor Voltage for switch time calculation
Min: 45,875
Test result value: 46,053
PASS
TID:$01 CID:$01
Max: 64
FAIL
TID:$02 CID:$01
Max: 64
PASS
TID:$02 CID:$02
Max: 64
PASS
TID:$03 CID:$01
Min: 45,875
PASS
TID:$05 CID:$02
- Rich to Lean sensor switch time(calculated)
Max: 21,568
Test result value: 21,557
PASS
TID:$05 CID:$03
Max: 30,368
PASS
TID:$06 CID:$01
- Lean to Rich sensor switch time(calculated)
Max: 25,000
Test result value: 283
PASS
TID:$06 CID:$02
Max: 25,000
Test result value: 203
PASS
TID:$08 CID:$01
- Maximum sensor Voltage for test cycle(calculated)
Min: 154
Test result value: 255
PASS
TID:$09 CID:$01
- Time between sensor transitions(calculated)
Max: 1,200
Test result value: 260
PASS
TID:$0a CID:$01
- Sensor period(calculated)
Max: 32,943 Min: 32,593
Test result value: 32,919
PASS
TID:$0a CID:$02
Max: 49,151 Min: 16,384
Test result value: 47,639
PASS
TID:$01 CID:$01
Max: 64
FAIL
TID:$02 CID:$01
Max: 64
PASS
TID:$02 CID:$02
Max: 64
PASS
TID:$03 CID:$01
Min: 45,875
PASS
TID:$05 CID:$02
Max: 21,568
PASS
TID:$05 CID:$03
Max: 30,368
PASS
TID:$06 CID:$01
Max: 25,000
PASS
TID:$06 CID:$02
Max: 25,000
PASS
End of report.
TID:$01 CID:$01
Max: 64
FAIL
TID:$01 CID:$01
Max: 64
FAIL
TID:$02 CID:$01
Max: 64
PASS
TID:$02 CID:$02
Max: 64
PASS
TID:$03 CID:$01
Min: 45,875
PASS
TID:$01 CID:$01
Max: 64
FAIL
TID:$02 CID:$01
Max: 64
PASS
TID:$02 CID:$02
Max: 64
PASS
TID:$03 CID:$01
Min: 45,875
PASS
TID:$05 CID:$02
Max: 21,568
PASS
TID:$05 CID:$03
Max: 30,368
PASS
TID:$06 CID:$01
Max: 25,000
PASS
TID:$06 CID:$02
Max: 25,000
PASS
TID:$08 CID:$01
Min: 154
PASS
TID:$09 CID:$01
Max: 1,200
PASS
TID:$0a CID:$01
PASS
TID:$0a CID:$02
PASS
TID:$01 CID:$01
Max: 64
FAIL
TID:$02 CID:$01
Max: 64
PASS
TID:$02 CID:$02
Max: 64
PASS
TID:$03 CID:$01
Min: 45,875
PASS
TID:$05 CID:$02
Max: 21,568
PASS
TID:$05 CID:$03
Max: 30,368
PASS
TID:$06 CID:$01
Max: 25,000
PASS
TID:$06 CID:$02
Max: 25,000
PASS
End of report.
Found this doc on O2 sensors, thought I'd attach it.
I seem to recall torque saying my car was not running in closed loop.
There seems to be many ways to check the upstream sensor, such as pullinh a vacuum line, or spraying propane into the intake, but how do you test the downstream sensor?
Maybe if I put my stock pulley back on I might pass? That should help to reduce leanness?
2004 Civic Si. FWD for the Win!
They have these things called "shops" where they truly know what they're doing, and have the experience to correctly diagnose your issue. I hear they can be helpful!
Shops? That's what Roxy like to do. Shop.
I don't need no stinkin' shop!
For the price of just the diagnostic, and I could buy both 02 sensors.
Well, thing is, I have one O2 sensor that's original (downstream) and one that has over 100K miles (upstream) so per mercedes they should be replaced either way.
Thing is I'm not really clear on what the purpose of the downstream sensor is, or if it would play a part in getting the lean condition.
Good news is my evap system finally went ready. So if I can fix the lean condition, (perhaps put the stock crank pulley back on?) I can pass smog.
Political corruption has it perks.
Ah, to be NJ again and be able to just pay people off.
Cali, people are so by the f'ing book.
