HELP....cranking help
Old Apr 24, 2014 | 05:12 PM
pookdogg's Avatar
2001 c240
I have a 2001 w203 c240, 146,000 miles, drove it about 2hrs the other day got home it sat til the next day, it started up and was running then it died googled and youtubed info had the CPS changed.... and BOTH fuel pumps and still nothing it just turns over....and YES I did check the relay..... now im stumped please help me
Old Apr 24, 2014 | 05:36 PM
Alswag's Avatar
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
Check fuel pressure. I'd make sure your injectors aren't clogged. But to be safe, you'd be better off getting a dealer/indy to use an SDS on the car for a proper diagnosis. It'll show you magical things you never knew you could see.
Old Apr 24, 2014 | 06:57 PM
pookdogg's Avatar
2001 c240
ok ill check that, would a fuel filter cause these problems?
Old Apr 25, 2014 | 12:29 PM
Alswag's Avatar
A clogged filter could also cause these problems, though from my experience it doesn't happen often. Again, get it scanned and check it out.
Old Apr 26, 2014 | 09:20 AM
pookdogg's Avatar
2001 c240
car has no codes, so far ive changed the CPS, fuel pump and sending unit, and fuel filter car is still not starting. its got spark cause I spray a little starter fluid( I KNOW I KNOW a no-no) in the MAF and it started up... im at my limit with this stupid a$$ car
Old Apr 26, 2014 | 11:15 AM
cm60k's Avatar
Do you try to open the fuel hose(at the Engine bay), and when you start the car to see if fuel reaches to injectors...?!?
ZAYED,,
Old Apr 26, 2014 | 12:05 PM
pookdogg's Avatar
2001 c240
where would that be? at this point ill try anything
Old Apr 26, 2014 | 12:13 PM
pookdogg's Avatar
2001 c240
seems like theres no pressure on the rail
Old Apr 26, 2014 | 12:21 PM
cm60k's Avatar
The braided hose that goes to the fuel rail(for injector feed), if there is fuel reaches there, that will fine,
then you have to check the starter fuse 31 or 52 or 57 in the front fuse box(SAM)....
ZAYED,,
Old Apr 26, 2014 | 12:49 PM
pookdogg's Avatar
2001 c240
checking now, but heres something ....shouldn't it be gas in BOTH tanks? because the drivers side where the sendind unit is completely dry
Old Apr 26, 2014 | 02:54 PM
cm60k's Avatar
As i know; you should have "2" fuel sender units, both feed each other, maybe this is the issue you have,
did you check the starter fuse in the front fuse box(SAM) first...??
ZAYED,,
Old Apr 26, 2014 | 03:17 PM
pookdogg's Avatar
2001 c240
ZAYED,,
seems there is no power to the pump
Old Apr 26, 2014 | 04:10 PM
1st lite's Avatar
2002 C240
When put the key in the ignition and turn it to "position 2", you should hear a humming/vibrating sound from the fuel pump for approx. 2-3 seconds. If you don't hear anything, you may have a faulty pump or no power getting to it. Keep us posted on what the problem is.
Old Apr 26, 2014 | 04:15 PM
pookdogg's Avatar
2001 c240
theres no power to the pump
Old Apr 26, 2014 | 04:23 PM
cm60k's Avatar
Means fuse/relay on front or rear SAM modules...!??!
ZAYED,,
Old Apr 26, 2014 | 04:32 PM
pookdogg's Avatar
2001 c240
ZAYED,,
the relay is good in the rear I can hear it clicking where is the one in the front? is it #57?
Old Apr 27, 2014 | 12:33 AM
cm60k's Avatar
I think the front one comes as a "Starter relay", # 31 or 52 or 57, check that....
ZAYED,,
Old Apr 27, 2014 | 01:42 AM
pookdogg's Avatar
2001 c240
ZAYED,,
ill be on it first thing in the morning againg
Old Apr 28, 2014 | 11:05 AM
pookdogg's Avatar
2001 c240
ok switched out the relays, the old was working (I THINK) because the gas hand wasn't working...switched it out for one in the front.... it started back working BUT car still hasn't started....I don't know where to go from here
Old Apr 28, 2014 | 11:28 AM
cm60k's Avatar
Do you have a fuse # 4 in the trunk, i assume it's for fuel pump either...!!
ZAYED,,
Old Apr 28, 2014 | 02:04 PM
pookdogg's Avatar
2001 c240
ZAYED,,
fuse #4 is good could a bad ECU be the problem? because theres no fuel going to the injectors
Old Apr 28, 2014 | 04:12 PM
cm60k's Avatar
Ohh, i hope not ECU,
need careFULLY to inspect the wiring or the Electric power that goes to the rear SAM, or the fuel wiring itself....?!!?
ZAYED,,
Old Apr 28, 2014 | 04:13 PM
cm60k's Avatar
Old Apr 29, 2014 | 09:46 AM
pookdogg's Avatar
2001 c240
ZAYED,,
how would I check the rear SAM? I think its working because I can hear the relay clicking when the key is position #2.....so I figured it was the ECU? you think resetting it would help?
Old Apr 29, 2014 | 11:18 AM
cm60k's Avatar
I don't think reset will help,, reset in another thing, the mystery things, why no power goes to the fuel pump,
of course ECU could do that, try to unplug the ECU & see maybe some of elecrrical pins loosing or something....!!
ZAYED,,
