Any idea what this is?
Old Apr 30, 2014 | 01:42 AM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
[IMG][/IMG]
Anyone knows what is this part Circled in yellow? I noticed it has a bit of oil when I was putting the plastic cover after replacing the lower control arm.
Thanks everyone.
Old Apr 30, 2014 | 05:19 AM
cm60k's Avatar
These are a plugs for a Torque Converter Port,
in case you want to be sure if Converter has leak or not, just unplug one of them...
ZAYED,,
Old Apr 30, 2014 | 01:57 PM
samaritrey's Avatar
Super Moderator
THE C350
Usually the oil comes from the rear main engine seal mine is leaking pretty bad on my c320 and has for over 50,000 miles
Old Apr 30, 2014 | 02:59 PM
SlvrC230SS's Avatar
I need to trace it again. Majority that seems like caused by rear main seal based on what I searched on google. If so, then it's going to be expensive cuz transmission needs to be removed in order to replace the seal. What's usually cause the leak? is this typical?
