confused about climate control
-How does does the air distribution work with "Auto" selected?
-Is "EC" an "Auto" without air conditioning? so does this mean if it gets too hot, it will shut itself off until it is triggered by a temperature fall?
-I figured I can activate "EC" too when "Auto" is on but when "EC" is on by itself, pressing "Auto" will deactivate "EC". What is going on?
-In general should I usually leave it on "Auto"?
It's getting cold around here and it would be nice to master the climate control.
I thought that if you selected Auto, it would automatically try to get to whatever temperature you have selected. So, if you put it to 72, and its 82 inside the car, it will kick on the AC compressor to cool the car down.
I understood that if you selected EC (in addition to Auto), you are in "Economy" mode. The car will still try to regulate to whatever temp you set, EXCEPT in EC the AC compressor will NOT go on. So, if you select 72 and its 82 in the car, it will try to cool it down using just the fan (of course, it will never get to 72 without the compressor, but it will try).
The thing that seems to happen, though, is when you select EC it shuts down the compressor, but also goes into some kind of recirculation mode. I've found with EC on, the interior tends to get very stuffy and humid.
I am not one who likes to run the compressor at all times. I would like it if I could just get some straight damn fresh air through the vents, but the it seems difficult to get just straight, unprocessed air.
So, now I just leave it on Auto all the time. Its the easiest and seems to keep the interior air the freshest.
Hope this helps.
What I would really like, and what would suit my climate, is no ac compressor and just pure, unprocessed air blowing through the vents. I can't seem to get that!
I believe the "Rest" function will run for about 10 minutes and then shut off, or you can press the button again to turn it off.
Hope this helps.
