In-Hood Fuse Panel Plug?
Old Dec 10, 2003 | 08:51 PM
c class 279's Avatar
M
Hey guys,
I'm in need of a plug so I can tap the speed pulse on the bottom of the underhood fuse box for my 463 Euro Command. I've got all the wiring routed, but I need to find someway to tap this plug. Does anyone know how? Steve told me I need to go to Radio Shack and get a:
"it is just a standard
connector that is available from any radioshack that is usually used for all
kind of electronic connections...just look in the rack at your local
radioshack for a standard flat female connector..."
Hmmmmm. The white thing in the pic w/ the yellow wire running out is what i need, however Steve said above that I just need something to tap that one pin. Hmph.
Old Dec 10, 2003 | 09:09 PM
vraa's Avatar
Not sure what this is, but EB Wing wanted me to post them here.
Old Dec 11, 2003 | 06:28 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I'm sure Steve means for you to do this.
Old Dec 11, 2003 | 07:40 AM
rsyed's Avatar
C200 CDI w203
mine is just taped to plug 24, pin 3 and it has worked fine for the last year or so!
greetings from vienna
