Trouble code p0355
Old Aug 18, 2014 | 05:13 PM
ebudd1973's Avatar
2006 mercedes benz c230 sport
Trouble code p0355
Hi all in forum land, I have a 2006 c230 sedan . Recently I decided to use my code scanner to check and see what may be the cause what I have been noticing as a lose of power. While the power lose that I have been noticing is very pronounced and I couldn't tell if it was real or just in my head cuz my car has no check engine light on . However once I ran a scan on it the DTC p0355 came up so I cleared it ,but the scanner said the computer still had the code stored in it. Does anyone have any knowledge of this problem and what I might do to resolve it? Thanks in advance. Ebudd1973
Old Aug 18, 2014 | 05:31 PM
cvx's Avatar
cvx
W203 C200CDI
Already seen this? http://engine-codes.com/p0355_mercedes-benz.html
P0355 Mercedes-Benz - Ignition Coil 5 Primary/Secondary Circuit Malfunction
Possible causes
- Faulty Ignition Coil 5
- Ignition Coil 5 harness is open or shorted
- Ignition Coil 5 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
Old Aug 18, 2014 | 05:32 PM
cm60k's Avatar
^^+1^^
ZAYED,,
Old Aug 18, 2014 | 05:40 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Nice website
There is a document in the Wiki as well https://mbworld.org/wiki/images/f/f5...stic_codes.pdf
Old Oct 1, 2017 | 11:33 AM
Tom Ard's Avatar
C280 4MATIC
P0355 Coil E
Is Coil E the same as cylinder 5 (Middle on Drivers side) ? I don't see any references to E to cylinder numbers!
