door dcm goes dead how to wake it up
Old Aug 19, 2014 | 01:57 PM
triffer's Avatar
2003 c class coupe 220cdi
My door has been losimg power when it likes normally after you open the window changed d.c.m. 3 times been told its a wire fault by people but found this by accident
If it goes dead stop the car keys out get out lock the car use emergency key to lock drivers side door open the door with the emergency key and doors locked indicator flash while your getting in place normal key in ignition turn to position 2 and if yor lucky try the window and its back to life if your lucky happened last time did it by accident just put window down leavin work and thought what the hell and it worked again? No idea why but im happy its working again nothing to lose by trying...
