Mirror indicator and seat
Two problems have come up today which may need my attention.
1. Front passenger seat will not adjust forward after a certain point. It is a manual seat and feels like it is jammed. The electric angle and up down thing works fine, but I can't move the seat forward. It is like it is jammed from one side, as it pulls more on one side than the other. How can I resolve this, and what is likely to be the problem. The seat is so badly stuck that at its most forward point, there is 6 inches from the back seat and about 3 ft from the front.
2. The mirror indicator is not working. I um, bent the mirror the wrong way during a reversing manouver and now it's not working. The mirror is not folding. The electronic adjustment works good but the indicator is a no no. I get the message on my dash to check the bulb. How would I resolve this.
Zain
You don't need to remove the mirror glass, just adjust it to the max right.
I'd guess some of the pins in the blinker connector are bent.
For the seat, have you checked underneath, on the rails - sounds like something is stuck in there.
Thanks for your reply.
I intend to strip the mirror down to see what the damage is. Thanks for the video, it will help greatly.
To see beneath the seat rails, would I need to take the seat out or is it accessible from anywhere. It's the side by the centre panel btw
Thanks for your help so far.
Been busy lately but found some time to spend with the car. The mirror indicator was a weird one. I tinkered with it for about an hour, no result. I then bent it the wrong way again and good as new. Odd that...
Seat is beating me though. I looked around underneath the rails for obstructions but I can't see anything. I think something may be between the rail and seat. I tried to remove the seat by taking out the front two bolts, slid the seat forwArd, but it was too far back to access the rear bolts. So I can't even pull the seat out. Is there a way to detach the seat from the rail, then remove the rail from the car? I think this is the only last option I have...
Cheers
