C320 overhead dome light W203
Old Oct 2, 2014 | 07:20 AM
jackofspades40's Avatar
2003 C320 Wagon
How do you remove the map lens to replace the bulb in the overhead dome light on a 2003 C320 W203? I tried pulling it off, but afraid the lens will break. - Thanks-
Old Oct 2, 2014 | 09:31 AM
ildd's Avatar
2002 c240
Get a small flathead, wrap some tape around it and gently pry it off. It will snap back on.
Old Oct 2, 2014 | 05:16 PM
2003 C320 Wagon
Thanks...I'll try it tonight...very carefully :-)
Old Oct 15, 2014 | 08:04 PM
2003 C320 Wagon
UPDATE: Found out how to remove the front overhead dome light. First you have to remove the large lens cover revealing the main dome light bulb (small screwdriver in the part facing the rear of the vehicle). In there are two 'levers'...pull them toward the rear of the vehicle and pull down slightly...the entire overhead dome light unit will pull out. BTW...this is the only way to replace the map light bulbs.
Old Oct 15, 2014 | 09:31 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Yes, that's right - need to get through that bulb area to the other. It's really a(nother) badly engineered thing on these cars.
Old Apr 15, 2015 | 08:33 PM
jamieh64's Avatar
2009 C63
This (#4) is exactly 100% correct and so simple it's maddening !! Thank God I found this, I was going nuts ..
