19 inch wheel problem
i just put on a set of 19 in. wald replicas 19x8.5 - 235/35 and 19 x 9.5 265-30, and only my right front wheel is rubbing my strut (metal on metal) when making hard rights , or whenever i go in reverse......
i want to change the front struts anyway since they are bad.... could the strut be bent to cause this rubbing??... i wanted to hear some opinions to remedy this issue...
thanks
i remember someone posted a c-sedan with the same rims.. i'll post a pic when i have time
i have an 02 c230 with h&r springs (w/ about 22,000 miles on 'em)... factory struts and shocks (which was a bad move to keep on)...
thanks
Ok I have this wheel also on my benz..
I know this wheels got lettle bit problem with the offset speacialy for the front.
mine i just used 225/35/19 and spacer 3mm or 5mm
if not the rims will rubb with the strut...
thats I used right now...
