Help on Radio
Help on Radio
Today, i was driving my C240 & listen to radio, sudden the radio stop & couple seconds later, it came back, no matter which channel, it happened in different time. I thought it was some setting related to speed, it will break when drive fast but it still happened during I slowed down the car at traffic light.
Anyone can give me some idea how to fix this? thanks
I can help, for a small fee.
It will play and about evey 4 seconds it cuts out for a second, and so on?
Mine has done this a couple times in its life. Turning the radio on/off doesn't fixt it, in my case. Turn the car off and remove/reinsert the key a few times. Just in and out, no turning of the key. Then, restart the car and you are golden.
That, or you could bring it into the dealer, and wait while they fail to re-create the problem
I have no idea, but it works for me.
-John
-John
Originally posted by Addy
Really?! I'll try it but do you what is the cause? How should the key in/out would fix this problem? thanks a lot
Here's one possible solution...
Do you have an integrated phone installed? If you have a phone installed and you have a voicemail message waiting, the only "handy" indication of this is that your audio will cut out momentarily while your phone tries to tell you you have a message. Disregard if you don't have a phone.
