buttons above the radio don't work
Old Nov 21, 2014 | 03:03 PM
rpbtos's Avatar
c230
So... All the button above the radio do not work... The hazard lights, ESP button, unlock/lock .. at night the lights do not light up either..
IS there a fuse that i need to replace or is the whole unit out?
Old Nov 22, 2014 | 07:11 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Could be a fuse, or could be that the plug fell out. at the back of the unit. Check the fuse first.
To remove the trim piece, follow the radio removal instructions. Obviously you'll only need to do the first few steps or so.
Old Nov 22, 2014 | 12:45 PM
rpbtos's Avatar
c230
Is the fuse on the panel by the door? if so what is the fuse number that i need to replace?
Thank you
Old Nov 22, 2014 | 08:14 PM
KSKarl's Avatar
2002 C230 Coupe
In my car, the lock and ESP switches work, but not the seat heaters. Lights don't come on in the seat heater switches when I press them. Checked fuse 25 and 41 OK. What do I check next?
Old Dec 8, 2014 | 03:44 PM
rpbtos's Avatar
c230
I checked all the fuses by the driver side and they're all good.
What else can it be...?
Old Dec 8, 2014 | 03:55 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
My guess is the front SAM. But then that's my response in general now, since they seem to be going here fairly frequently now.
Old Dec 8, 2014 | 03:58 PM
rpbtos's Avatar
c230
is that the whole module that holds all those buttons (Hazard light, ESP.. )?
Old Dec 8, 2014 | 04:32 PM
tommy's Avatar
It's basically the assembly behind the electronics for the front end. Do a search, you'll come up with a lot of threads here.
Old Dec 10, 2014 | 12:53 PM
rpbtos's Avatar
c230
would that be the fuse box thing located by the driver side? I searched all over but different models come up and they're all in different places....
Old Dec 10, 2014 | 05:20 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
If you do an 'Advanced Search', you will be able to choose which forum(s) to restrict your search (click on the one you want, CTRL click on the ones you want).
