Leaving jack on rear diff. while draining it?
Drain plug is on the passenger side. Fill plug is on the drivers side.
Loosen and remove fill plug, remove drain plug and let old fluid drain.
Put new o-ring on the drain plug and put back the drain plug.
Pour new fluid in to the diff until fluid starts to pour out. Put new o-ring on the fill plug and put back the fill plug. Tighten both plugs to correct torque. Wipe off the area with brake parts cleaner.
