Haalp !, W203 Oil leak (pic) :(
Do you or anyone know the part for sure ? I found this off a Russian website, part number is A 120 997 03 46, #8 in the diagram.
if that is the part, is this the only thing I need ? also while i'm at it, do you recommend changing any other parts while getting the job done ?
Thanks !
Crank seal came in today, was planning to work on it over the weekend, however, the car won't start anymore (see thread) so i might end up spending the weekend fixing that, seems like bad connectors or a faulty ECU
, will keep you guys updated when i start working on the seal and post some pics of the procedure !
i just had a quick question before i remove the old seal !
will oil gush out if i remove the old seal ? should i empty the oil before doing the job ?
or is it ok to replace the seal with the oil in there ?
thanks !
thanks !
Started by getting the belts off yesterday and ended up suck cause I didn't have the right size socket, getting that today after work to continue job, will keep you guys updated !
first thing thanks a lot for the help everyone!
You're absolutely right , matter of fact the front of the car is lifted so i can get under, which will even push any extra oil away !
So here's what i've done till now:
1-Remove the radiator fan (not necessary for everyone, but my breaker bar extension was too long so i had to for clearance !)
2-Killed myself trying to get the pulley bolt off, i'm ashamed of the way i did it, but i had no choice, i had to crank the engine with the breaker bar laying on the garage floor, couple of little cranks and the nut was off.
3-Pulled off the pulley using a hub puller (that thing wouldn't come off any other way, i'm lucky i had a puller laying around !)
4-I'm at this stage now, damn look at that mess !
I had a couple last question before replacing the seal !
A- Does it come off by prying it out with a flat screwdriver ? or is there's something I should know ?
B- I'm worried about reusing the pulley bolt, is it safe to reuse that ? or should i get a new one ?
have a nice day !
It's been a hard time and i forgot to update the post !
Almost 4 months now and the car has been running happily with no more oil leaks !
i didn't manage to get pictures of the job being done in reverse order, but it's pretty straight forward !
it was just extremely difficult to torque the new bolt since that requires locking the engine some way or another, there's a special tool from MB for that, i totally recommend getting it as you don't want to cause any minor kinks in your harmonic balancer, trust me
I ended up building my own tool to hold it in place by using metal parts that i had around, i'm not gonna explain why cause i don't want to encourage anyone to go the DIY route, get the proper tool instead, it'll save you a lot of pain.
thanks for the help guys, it's been a bumpy ride
going to prepare the car to get some minor rust spots removed, besides that, it's going perfect !
