Camshaft magnet oil is leaking, which part to replace?
Old Jan 4, 2015 | 10:31 PM
chazzz's Avatar
'05 MBZ C230K and '09 MBZ C350
My wife drives her 2005 Mercedes C230 Kompressor. The oil is seeping through the camshaft magnets.
I'm sure that the camshaft magnets are OK. They need new gasket (O-ring) to stop/delay the oil leak. Can I just replace the gaskets? or do I have to buy everything: camshaft magnets and O-ring gaskets?
I will also need to buy new isolation wires. The current isolation wires are soaked with oil. Where can I buy them?
thanks
Old Jan 5, 2015 | 11:31 AM
chazzz's Avatar
After 57 or so views, no one knows how to answer my questions??? Can I reuse the camshaft magnets while replacing the O-ring seal gaskets?
I found the isolation wires (known as "adapter cable") online... www.factorymoparparts.com sells them for $28.91 each!!! Many other places sell for $35-$45 each.
Old Jan 5, 2015 | 01:05 PM
Cruel-Merc's Avatar
2009 C350
Hey man, i had the same problem, noticed few days ago that there was some oil leaking from both magnets , so i had to change the whole two magnets and not only the gaskets plus the isolation wires as mine had oil in them.
