those rubber thingies for the suspensions
Old Mar 19, 2002 | 07:06 PM
born2drive's Avatar
2002 C 240
Talking those rubber thingies for the suspensions
I believe they are called "rubber shimms perch".
Someone told me that how low your car sits depends on what size of rubber shimms perch I have. It varries from 8mm - 23mm.
Then my question is, what size of perch does the C240 use?
And let's just say C240 use other than 8mm, do you guys reccomend if I change to 8mm perch to go with H&R cupkit?
Will those perch make the car lower?
Old Mar 19, 2002 | 07:16 PM
Harris's Avatar
Yes, those are called shim perch. But you can only find them on the rear. I dont think changing the shim perch will help you drop the car in a "noticeable" way. Getting the cup kit is already low enough for yr C. I really wouldnt go lower than this.
My C32 comes with the Dot 2 shim perch. Sorry, I have no idea what thickness do C240s come with.
Old Mar 20, 2002 | 12:56 AM
born2drive's Avatar
2002 C 240
thanks harris for the reply
so anybody knows what size of perch does a C240 use?
