c180 2003 auto issues. :(
Old Jan 10, 2015 | 07:02 PM
simon0000's Avatar
c180 kompressor
Exclamation c180 2003 auto issues. :(
ANY HELP PLEASE GUYS...
I bought the c180 2003 kompressor 80,000miles after being sat on a drive for approx 12month, numerous issues are showing up on the dash.
Ive noticed the engine running ruff on idle,
I had it plugged in with a computer and faults/codes showed up.
*battery alternator visit workshop
*under voltage switch consumers off
*P0301/2/3/4 cylinder 1,2,3,4 misfire detected
*P0620 Generator contol circuit.
*P0130 o2 sensor circuit (bank 1 sensor 1)
Im going to remove plugs and either clean or replace depending.
run fuel/injector cleaner through system
drop oil and replace with filter.
Previously the car was serviced regularly by elderly man.
Any help will be very helpfull as i have never owned a mercedes before.
Old Jan 10, 2015 | 07:10 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Start with a new battery and the alternator check-up.
All those errors might be popping up due to undervoltage, so you might be able to get away with just a battery.
