How to tell if check Coolant level is DOOM and GLOOM
About 4 months ago I did a coolant flush so I'm worried b/c the Check Coolant Level indicator went off and when I checked the coolant reservoir is like half empty so I'm paranoid that the coolant's leaking into the transmission or worse (head gasket?) b/c that's my freaking luck. I'm doing a transmission drain and refill (not dropping the pan- did that 3 thousand miles ago). Is there a way to know based on the transmission fluid that I drain if coolant is leaking into it? Obviously I'm gonna take off the under panels to see if there is a leak in the first place, but I'm already thinking ahead. Also, at the moment the car runs fine, normal operating temperatures too
thanks!!
