Having problems with my LEDs!!! Help !!!!
On a side note...LED bulbs are great for turn signals, brake lamps etc but are not practical on a W203 headlamp or indeed any other car they are not designed for. The reflector bowl in your headlamps is not designed for LED bulbs, which have different light output characteristics compared to gas bulbs. They will look brighter but the amount of light they project onto the road (lumens) will be low.
THE NEW LED'S DON'T HAVE ENOUGH RESISTANCE TO SATISFY THE LIGHT CIRCUIT SO YOU WILL GET INTERMITTENT LIGHTING
-AND POSSIBLY A FAILED LIGHT WARNING ON YOUR DASH DISPLAY.
YOU'LL NEED TO PUT A LOAD IN EACH LIGHT CIRCUIT VIA A RESISTOR.
WHERE DID YOU BUY YOUR LIGHTS?, THEY SHOULD HAVE ALSO OFFERED THE ACCOMPANYING RESISTORS TOO.
I'M TRYING TO FIND THE BEST LEDS TO REPLACE MY LOWS ALSO BUT HAVEN'T
FIGURED IT OUT YET.GOOD LUCK SIR
WOW; THANKS RWD, I DIDN'T KNOW THE LATTER PART OF YOUR STATEMENT. SO I SHOULD JUST MAINTAIN THE H-7 BULBS FOR THE MAIN LIGHTS? ANY PREFERENCE?
Additionally, LED bulbs will require load resistors which get VERY hot. I have LED bulbs for my brake lights and turn signals, but since those lights are not on continuously, the heat is not that much. I did not install LED bulbs for the tail lamps. If you use LED bulbs in conjunction with your headlamps you will have to mount the resistors against a metal component to act as a heat sink, otherwise something will melt.
Hope this helps.
Unfortunately, the truth is there is no high power led headlamp bulb that will satisfy you as earlier mentioned. It can not be possible as of yet. It does not emit 360 deg. More LEDs more heat. I've been testing dozens of manufactured led bulbs on many model cars. None are satisfactory. I tried everything out there. 3rd gen Multi dome Crees to large flat LEDs. They are very brighter than incandescent but don't reflect properly in a housing designed for halogen bulbs.
