w203 c200k catalytic converter
w203 200 kompressor
Hello everyone!
I have mb w203 c200k m111 engine. A few days ago,check engine light on my car is on. Diagnostic says,catalytic convertor not in function. Is that mean that catalityc convertor is gone dead,or what? Can someone please tell me part number for original catalytic converter and for the aftermarket one also. Sorry for my bad english. My regards.
w203 200 kompressor
Ok,thank you. I will check on their website for catalytic convertor. One more question,if I remove catalytic convertor and somehow shut off signal from o2 sensor. What will happen with fuel consumption if I do that? My regards!
Yes, I've had years of success with my Magnaflow on my M111, and it was about $1100 cheaper than the OEM replacement.
Interesting second question. My guess is that the car would go into limp mode, and the ecu would pick a "safe" air/fuel mixture until everything got hooked up again, but I wouldn't recommend doing it.
1 Post
2002 C230 Coupe
You're right, Tommy. If the O2 sensor is disconnected, you get check engine light and a code. If the sensor ahead of the cat is out, the ECU will probably go to limp home mode. Not sure what the sensor after the cat would do to its operation. In my case the cat itself is shot, so the downstream sensor sends the dirty value causing the error message. Upstream sensor still controls air/fuel ratio OK.
But the rescue dog has a couple more pressing issues -- cat is down the list a way.
w203 200 kompressor
Mercedes C200 Kompressor 2004 model
Cat converter
Hi Radek/Newbie.
I have a 2004 C200 Kompressor as I start the car after driving it to the shop where it was standing for 5 min. when it started with a rough idle and engine light was on could it be the Converter I've been to a exhaust shop and the guys told me to take it out completely and it will give me more power as the guys are doing this with bran new Golf Gti's anybody with advice if my Cat could be gone and do I need a replacement.Thanks.
