Steering wheel
Old Feb 17, 2015 | 08:29 AM
Julien-France's Avatar
sport coupe C200K
Steering wheel
Hi guys,
I need to replace my steering wheel (CL203 2002) that is in realy bad condition.
How should I proceed?
Mechanicaly, I believe that under the MB logo I'll find a big bolt, as it is on any car.
I believe I should put my wheels strait and take key out to have the column blocked.
But as there is the air bag, should I disconnect (-) on the batt?
I'm a bit afraid after reading all the problems linked to batt disconnect...
Should I go into "maintenance mode" before disconnect or will it have no impact?
Thanks for your help,
Julien
Old Feb 17, 2015 | 09:58 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Someone here posted up a very good DIY here about doing the steering wheel, and how to work with the airbag. Should be able to find it with a good search. Good luck.
Old Feb 17, 2015 | 11:18 AM
sport coupe C200K
Thanks Tommy
Old Feb 17, 2015 | 11:45 AM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
https://mbworld.org/forums/e-class-w...step-pics.html
The W203 version does not have pictures anymore, but it's pretty much the same.
No need to disconnect the battery, but make sure the key is nowhere near the ignition!
Old Feb 17, 2015 | 01:35 PM
sport coupe C200K
GREAT !!!
So no need to disconnect battery, that's cool.
how far should be the key? d'you just meen that it should NOT be used? or d'you meen realy far ?
little torx, Allen 10mm... perfect.
thanks guys, I'll take pictures.
Old Feb 17, 2015 | 02:30 PM
tommy's Avatar
He just meant to keep it as far away as necessary to ensure that you're not paranoid about it somehow going in the ignition. But I'd suggest that if you have someone with you, have them put it in their pocket.
Old habits die hard, and you might just out of habit stick it in if it's on your person or near you, and you don't want that.
Old Feb 17, 2015 | 09:39 PM
sport coupe C200K
By the way, as I'm looking for my parts at the junk yard, what if I find a steering wheel from second series (2004-2008) instead of first (2000-2004)?
Will it fit?
Wirings and connectors are the same?
Old Feb 17, 2015 | 10:19 PM
RCPDesigns's Avatar
2007 e350, 2013 C250, 2004 C320, 2003 C320, 1998 CLK 320
I needed a breaker bar to get the 10mm bolt out. Having a helper to hold the wheel helps as well as you are not supposed to let the steering lock hold the wheel (I think it might break it).
Here is the video I used. I found it very helpful.
