Replacing/fixing multi-function sensor wire
Old Feb 22, 2015 | 09:38 AM
cubanmissile's Avatar
2002 Mercedes-Benz C320 SPT
After toubleshooting my A/C quite a bit (the A/C does not cool or heat the car at all, just blows air), I found that the multi-function sensor plug and wire was chewed off by some animal (this must of happened before I bought the car, since the A/C never worked).
Due to the above, this causes STAR to throw the diagnostic message: Unable to communicate with multi-function sensor B/31.
How should I go about fixing this? The sensor is there, it's just that the wire and plug that goes into the sensor is missing/chewed off. So there's about 6-8 inches of missing wire, and the plug that plugs into the sensor housing.
Old Feb 22, 2015 | 11:15 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Can you get a plug from a junk yard? then splice the wires.
Old Feb 23, 2015 | 06:46 PM
Yeah, I figured I would have to do that, but I was curious to see if any of you guys have come across this or would know if someone somewhere sells the part haha. Thanks!
Old Feb 23, 2015 | 10:14 PM
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
You can get a new receptacle housing and wires with sockets already crimped from the dealer. Not too expensive, but they will have to order.
Housing A2205400681
wires A0005402505
Old Feb 23, 2015 | 10:22 PM
Housing A2205400681
wires A0005402505
Wow! Amazing, thank you so much, really!
